USB Audio Adapter for Zero W. How to get sound from it
No problem. You’ve highlighted some work we need to do, thanks.
Under Raspbian, BT audio ought to work with the package bluez-alsa. Check RPi forums for how to do it.
Thanks. What about the USB Audio Adapter?
Suggest to ask on the forum of the Operating System you have installed.
Raspberry Pi Forums - Index page if you have installed Raspbian.
Have just asked on there.
I found this,
Would this be the exact method on how to do it?
I’d suggest posting over on the Raspberry Pi forums.
