Quick question:
Is anyone experiencing this with the OSMC remote; or are you all suspending using a universal remote?
Quick question:
Also happens with OSMC remote only
Thanks.
same for me, using both the supplied remote or the iphone kodi app.
Same here with Vero 4K+ and OSMC RF remote control. I will post debug logs when I get home after work today.
Roman
Yes.
With both remotes the OSMC stock device as well as with an MSE remote.
When using the keyboard suspending works.
Yes, and I only use the supplied Vero 4K remote.
As promised: https://paste.osmc.tv/anopetiyit
Clean reboot, a few unsuccessful attempts at suspending, then a successful suspend. Hope that helps! ![]()
This should now be fixed.
Iād appreciate it if you could test this and provide feedback before we potentially release this as an update to other users. To test this update:
/etc/apt/sources.list
I installed the update and suspend mode is now working as expected.
Thank you, Sam!
Update installed, suspend now working properly, and as before.
Thanks very much Sam!
Great. Thanks for the feedback.
Sorry, I missed the updates to this threadā¦
I can confirm that it works for me now too.
Thanks a lot!
Sebastian
Sam-
Glad to see how quickly this issue was addressed!!
Will there be an easier way to update, which does not involve the ssh and edit/adding of files? Perhaps the grandfather approved download via My OSMC
Yes this will be included in the next stable update
Hi all!
With Kodi 18 my Vero 4K+ wasn“t able to suspend anymore so I followed post #32 and updated my Vero.
Now after the update I“m finally able to suspend the device and the red LED turns on but after couple of minutes the LED turns off. If I turn the TV on I immediately see the Kodi home screen.
I“m using the default OSMC skin without any special addons.
I have only the standard remote and during my tests didn“t run the iOS Kodi Remote.
HDMI CEC isn“t active.
I created the log files:
after the restart I suspended the Vero. After powerup I created the logs (I deleted lines with information about my movies/series)
https://paste.osmc.tv/ujoruluyon
Thanks!
Tamas
