@sam: I Copied a .ts file from the VDR Server to a stick:
- It does not work with the latest stable
- It does work with the nightly build
- (additionally) It works on my Linux-workstation as well with any media player
Please send a sample of it so I can reproduce the problem
Ok, you can find a file I just recorded and proved it does not work
here:
Holger
Thatâs useful. If I can reproduce the problem I can usually fix it. Thank you for the clip Holger. I will let you know how I get on with it.
Hi Sam,
is there anything else I can do to help?
Holger
I havenât had a chance to look in to this yet.
I will check it in a few days.
@sam_nazarko, is there any chance to get this any further?
Holger
Is only FF/RW affected and not seeking?
Sorry for the delay - I had to update to a recent version to test it.
Seeking is also affected. Nothing changed in the recent version.
Still 17.8-376 is the last version without this problem.
Can you please give honest information about whether you will deal with the problem. It exists for 8 months and I donât see any progress yet. Reminding every 3 months and then getting another query from you does not help to solve the problem.
If it is not possible for you to take care of this problem due to time or other reasons I have to think of another solution
Holger
I will check this again tonight, against the 4.9 kernel.
Hello Holger,
Some good news: the problem is at least resolved on our 4.9 kernel and I could play the file (your 0001.ts) smoothly.
I will look at building some potential fixes for our current 3.14 kernel, but there is no guarantee it can be fixed with this version. You may need to wait for the 4.9 kernel (or use the test builds) for this to work.
Thanks for your understanding,
Holger, please try this updated release for 3.14
/etc/apt/sources.list
If it doesnât work sufficiently, you will need to wait for the 4.9 release
Thank you very much, Sam! I Will try this latest tomorrow.
Holger
Have a good Easter and keep me posted
âeditâ
With the 4.9 Kernel everything works now.
Thanks for your ongoing work!
Holger
Hi @sam_nazarko , I tested it but unfortunately the problem still exists.
What irritates me ist, why it should work with the 4.9 Kernel.
It works with the current kernel and vero3-mediacenter-osmc (17.8-376). So I donât think it is a kernel issue.
Everything works as well with a plain Kodi on any of my Linux boxes.
For me this shows that it must be related to a change made in OSMC (not Kodi, not KernelâŚ) between version 17.8-376 and the following one. (The kernel is the same!)
However - I will try the test build now and report back if it fixes it.
Holger
Hi Holger - just to clarify, did you test on 3.14 and the new build I produced or did you immediately install the 4.9 kernel from the 4.9 thread?
The instructions I posted above do not install the 4.9 kernel
Dear @sam_nazarko, I first tested the 3.14 build and that did not change anything. After that I upgraded to the 4.9 Kernel. With the 4.9 kernel everything works.
Holger
Thanks for confirming.
Hello,
i am facing the same issue on a Vero4k+ with OSMC 2023.01-1 (Kernel 4.9.269-21-osmc)
While I can watch TV without any problems can not fast-forwards, rewind or jump within the recordings. Also it seems that the recordings are affected if i copy them to another PC.
I receive my signal from a Sat>IP server (Octopus M4) and store the recordings on my NAS. I have a 1Gbit Network connection (cable). I use VDR together with VNSI Server and Client, all are running locally on the Vero 4k+
What else can I provide you to help me find this bug?
Thanks in advance
This is quite an old thread and the user reports the problem as solved. I suggest a new thread with some logs.
