I would assume “uninstall”, while I don’t see any install/uninstall steps in your apt.log
Ok, maybe @sam_nazarko or @grahamh can take a look at your logs.
But one thinks still pops up, why did you set limited colour range, did you had a problem that you fixed with that?
Yes, i meant uninstall. I just needed to google some bash commands before getting them all removed, since i couldt find them in the gui. The logs are from before i tried the bash commands.
I think limited color range was set because it was recommended in the gui? Something about if you connected your vero to a tv you should use limited color range, and if you were connected to a pc monitor or such you should use full?
Here are the logs after some uninstalling: https://paste.osmc.tv/petocegizo
Something i did must have done the trick! Its now “waking” up when i turn off and on the tv and soundbar.
Gonna leave it for a few hours just to see if the problem is still there.
Thanks so far for the help!
