I’m sorry again, my fault ![]()
i mixed the testing in the two kernel. The device need multicast and then rtsp, but v4 hasn’t multicast and v3 hasn’t raw for rtsp, multicast working well.
I must test it another way
I see. Since the missing multicast seems to be an oversight, perhaps @sam_nazarko will produce a new kernel.
Looking at a copy of Debian Stretch (4.9), it has these MROUTE settings:
grep MROUTE config-4.9.0-15-amd64
CONFIG_IP_MROUTE=y
CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
CONFIG_IPV6_MROUTE=y
CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y
I can do this in a bit – there’s a few kernel changes that need to be made first before this can be merged in.
another one CONFIG_NETFILTER_XT_TARGET_CT
vero:~# grep CONFIG_NETFILTER_XT_TARGET_CT /boot/config-4.9.113-29-osmc
# CONFIG_NETFILTER_XT_TARGET_CT is not set
thank you both very much
Hi again.
I already have the kernel with the required config:
kernel-osmc (master)$ ls -1 *.deb
vero364-headers-4.9.113-35-osmc.deb
vero364-image-4.9.113-35-osmc.deb
vero364-image-debug-4.9.113-35-osmc.deb
vero364-kernel-4.9.113-35-osmc.deb
vero364-source-4.9.113-35-osmc.deb
and this is the diff:
--- a/package/kernel-osmc/patches/vero364-000-add-kernel-config.patch
+++ b/package/kernel-osmc/patches/vero364-000-add-kernel-config.patch
@@ -1,6 +1,6 @@
--- /dev/null 2021-03-25 22:18:28.982818921 +0000
+++ b/.config 2021-03-25 19:46:27.632268410 +0000
-@@ -0,0 +1,5995 @@
+@@ -0,0 +1,5998 @@
+# Automatically generated file; DO NOT EDIT.
+# Linux/arm64 4.9.113 Kernel Configuration
@@ -668,7 +668,10 @@
+# CONFIG_NET_IPIP is not set
+# CONFIG_NET_IPGRE_DEMUX is not set
+CONFIG_NET_IP_TUNNEL=m
-+# CONFIG_IP_MROUTE is not set
++CONFIG_IP_MROUTE=y
++# CONFIG_IP_MROUTE_MULTIPLE_TABLES is not set
++# CONFIG_IP_PIMSM_V1 is not set
++# CONFIG_IP_PIMSM_V2 is not set
+CONFIG_SYN_COOKIES=y
+# CONFIG_NET_IPVTI is not set
+CONFIG_NET_UDP_TUNNEL=m
@@ -800,7 +803,7 @@
+# CONFIG_NETFILTER_XT_TARGET_CHECKSUM is not set
+CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
+CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
-+# CONFIG_NETFILTER_XT_TARGET_CT is not set
++CONFIG_NETFILTER_XT_TARGET_CT=m
+# CONFIG_NETFILTER_XT_TARGET_DSCP is not set
+# CONFIG_NETFILTER_XT_TARGET_HL is not set
+# CONFIG_NETFILTER_XT_TARGET_HMARK is not set
but when I’m building I get a warning ask me about CONFIG_NF_CONNTRACK_ZONES, and it adds some entries
I would like to test it with qemu to check if everything is fine but I don’t know how I should do it, could you give me some advice
Thanks in advance.
I don’t think you will be able to run the kernel under QEMU.
What’s wrong with booting and checking it?
fear of a kernel panic or cyclical reboots or a brick …
Yes, I can confirm it does. Either answer N or include it (set to “is not set”) in your patch file to suppress the message.
yes i answered that and got a kernel
in the end, with sam_nazarko’s answer so confidently, I decided to install the kernel
now I’m testing everything
everything works fine
now I only have two requests:
add requested kernel configurations: CONFIG_IP_MROUTE and CONFIG_NETFILTER_XT_TARGET_CT, this is the config diff:
@@ -1,6 +1,6 @@
-@@ -0,0 +1,5995 @@
+@@ -0,0 +1,6000 @@
@@ -711,7 +714,9 @@
+# CONFIG_IPV6_FOU_TUNNEL is not set
+CONFIG_IPV6_MULTIPLE_TABLES=y
+# CONFIG_IPV6_SUBTREES is not set
-+# CONFIG_IPV6_MROUTE is not set
++CONFIG_IPV6_MROUTE=y
++# CONFIG_IPV6_MROUTE_MULTIPLE_TABLES is not set
++# CONFIG_IPV6_PIMSM_V2 is not set
+CONFIG_NETLABEL=y
+# CONFIG_ANDROID_PARANOID_NETWORK is not set
+# CONFIG_NETWORK_SECMARK is not set
@@ -800,7 +805,7 @@
And an advice or how to compile the external module like I’ve builded the kernel, from my debian amd64. I have read build.sh but it seems complicated
thanks a lot
sudo chroot /opt/osmc-tc/aarch64-toolchain-osmc /usr/bin/make -C /mnt/package/kernel-osmc/nat-rtsp-0.7+4.18 KERNELDIR=/mnt/package/kernel-osmc/files-headers/usr/src/vero364-headers-4.9.113-35-osmc
that request is resolved
Now v19 is in testing state, I can look at including these changes for you shortly.
Your modules should now be included in:
This is available as part of the Kodi v19 test builds. See [TESTING] Kodi v19 builds for Vero 4K / 4K +.
With the kernel that I built I cannot see 4k videos:
now with your new kernel 4.9.113-36 I can see them. I should have made some mistake but I don’t know.
This weekend I will compile nat-rtsp for this kernel and test it
Thank you so much.
after testing it I have checked that everything works fine
Thank you so much
Thanks again for headers: [package] [kernel-osmc] Ensure we have all headers on ARM64 platforms · osmc/osmc@0f0dd66 · GitHub
now I don’t need download sources
Can you confirm that all the modules you now need are included?
Sorry for the delay
yes, I confirm that all the modules I need are included.
Many thanks
