Hello,
To be sure that i 'm understanding
my config.text after modification:
# Warning: do not edit this file, or it could prevent your OSMC system from starting.
# If you wish to make changes, you should do so via My OSMC or edit the config-user.txt file in this directory
# Any changes that you make here will be overwritten as this file is managed by the OSMC via the update system
[pi4]
dtoverlay=rpivid-v4l2
arm_64bit=1
kernel=kernel.img
[all]
## dtoverlay=vc4-kms-v3d,cma-512
disable_overscan=1
start_x=1
disable_splash=1
disable_fw_kms_setup=1
hdmi_ignore_cec_init=1
include config-user.txt
[pi02]
## dtoverlay=vc4-kms-v3d,cma-256
dtoverlay=vc4-fkms-v3d
[pi4]
arm_64bit=1
kernel=kernel.img
[all]
disable_overscan=1
start_x=1
disable_splash=1
[pi02]
It works like a charm, but there’s no hdmi audio…
I tried with c4-kms-v3d and vc4-kms-dsi-7inch but I have a white screen…
Any idea for having hdmi audio and screen working together?
