10 bit and banding fixed?
Probably because you have 18gbps chipsets?
There are some improvements being worked on. What issues are you experiencing?
@sam_nazarko How’s this going? I’ve a 4k+ on order.
Cheers.
R.
I don’t have any progress on this just yet. I would like to release a new update shortly; but 422 output is still WIP.
As promised, I will give you an update when we have progress.
Thanks for your patience.
I’ve a delayed but soon to be shipped Vero 4k+ Am I better cancelling this till the fix is done as it won’t even be plugged in until then.
I see it’s not in the July update.
Cheers.
You can cancel your order by emailing support@osmc.tv with your order details. Keep in mind that there is a price rise due shortly.
422 is now able to receive more attention. It will be fixed, but it wasn’t feasible for us to target it in this update.
I’ll start a test thread when we have a solution.
I’m going to close this thread as some users have emailed and are confused about whether 10-bit output support is possible and if banding issues are fixed. 10-bit and banding issues are resolved for some time.
I’ll start a new thread for 422 output post-resolution which is a different issue to the originally reported, and resolved problem.
