since a couple of weeks ago my raspberry pi 2 could not run any 1080P 60FPS videos smoothly be it from youtube or local playback. Previously 1080p 60 videos can be played and videos below that can be played even at 1.5x speed. I don’t remember changing any settings
What codec are the videos? Provide mediainfo (first step) and debug logs (second step).
No direct clue from the logs for me.
Have you tried to download the file and play it locally to exclude a stream/buffer issue?
I think if you have a local file that gives problems it will be much easier to analyse than via the youtube addon.
13:43:20.924 T:1925487104 NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
Suggest to check your audio sink configuration
Erm how do I do that?
Settings -> System -> Audio
I don’t see a “audio sink” setting to change. Changing random settings seem to not to fix it.
Disabling MMAL hardware acceleration seems to let the video play smoothly but no audio will play.
Disabling both MMAL and OMXplayer will make the video play but frames will skip and the CPU will go to 100%
What do you have under Settings -> System -> Audio -> Audio Output Device? It should be HDMI.
I use a usb speaker. Looking at Kodi changlogs for 17.6 it seems omx does not support it… Using 3.5mm audio jack speaker audio and video works…
Danm shame I cant use my usb speaker anymore.
Good find, that explains it.
