I am on the latest version.
Here is the link to the debug log: http://paste.osmc.io/jiqidenite
General
Unique ID : 208357811460086636304204481828897852115 (0x9CC0413C21E2B6A1A85D505F68BA8AD3)
Complete name : \freenas\Windows Files\Videos\HDMovies\X-Men Days of Future Past The Rogue Cut\X-Men.Days.of.Future.Past.2014.The.Rogue.Cut.BluRay.Remux.1080p.AVC.DTS.HD.MA.7.1-BMF\X-Men.Days.of.Future.Past.2014.The.Rogue.Cut.BluRay.Remux.1080p.AVC.DTS.HD.MA.7.1-BMF.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 31.1 GiB
Duration : 2h 28mn
Overall bit rate : 29.9 Mbps
Encoded date : UTC 2015-07-10 11:03:38
Writing application : mkvmerge v8.1.0 (‘Psychedelic Postcard’) 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 28mn
Bit rate mode : Variable
Maximum bit rate : 35.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : MPEG-4 AVC Video / 24435 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 28mn
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Title : DTS-HD Master Audio / 7.1 / 48 kHz / 5389 kbps / 24-bit
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 2h 28mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Compression mode : Lossy
Stream size : 238 MiB (1%)
Title : Commentary by Director Bryan Singer and Composer/Film Editor John Ottman / Dolby Digital Audio / 2.0 / 48 kHz / 224 kbps
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Language : Danish
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Title : Commentary
Language : Danish
Default : No
Forced : No
Text #4
Format : PGS
Muxing mode : zlib
Language : Finnish
Default : No
Forced : No
Text #5
Format : PGS
Muxing mode : zlib
Title : Commentary
Language : Finnish
Default : No
Forced : No
Text #6
Format : PGS
Muxing mode : zlib
Language : Italian
Default : No
Forced : No
Text #7
Format : PGS
Muxing mode : zlib
Title : Commentary
Language : Italian
Default : No
Forced : No
Text #8
Format : PGS
Muxing mode : zlib
Language : Norwegian
Default : No
Forced : No
Text #9
Format : PGS
Muxing mode : zlib
Title : Commentary
Default : No
Forced : No
Text #10
Format : PGS
Muxing mode : zlib
Language : Swedish
Default : No
Forced : No
Text #11
Format : PGS
Muxing mode : zlib
Title : Commentary
Language : Swedish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:03:33.338 : en:Chapter 2
00:08:04.734 : en:Chapter 3
00:10:34.217 : en:Chapter 4
00:15:11.410 : en:Chapter 5
00:18:44.248 : en:Chapter 6
00:22:43.529 : en:Chapter 7
00:24:38.769 : en:Chapter 8
00:29:05.619 : en:Chapter 9
00:33:03.440 : en:Chapter 10
00:37:11.896 : en:Chapter 11
00:38:49.827 : en:Chapter 12
00:41:06.923 : en:Chapter 13
00:43:50.336 : en:Chapter 14
00:50:05.377 : en:Chapter 15
00:52:07.082 : en:Chapter 16
00:55:11.391 : en:Chapter 17
00:57:56.348 : en:Chapter 18
01:01:04.661 : en:Chapter 19
01:04:01.421 : en:Chapter 20
01:06:39.829 : en:Chapter 21
01:10:22.802 : en:Chapter 22
01:13:00.459 : en:Chapter 23
01:16:28.334 : en:Chapter 24
01:18:48.724 : en:Chapter 25
01:20:44.590 : en:Chapter 26
01:22:46.962 : en:Chapter 27
01:28:07.574 : en:Chapter 28
01:31:19.057 : en:Chapter 29
01:33:50.958 : en:Chapter 30
01:39:22.373 : en:Chapter 31
01:42:10.291 : en:Chapter 32
01:44:32.016 : en:Chapter 33
01:49:13.547 : en:Chapter 34
01:51:00.862 : en:Chapter 35
01:54:54.304 : en:Chapter 36
01:59:15.940 : en:Chapter 37
02:02:13.743 : en:Chapter 38
02:04:30.504 : en:Chapter 39
02:08:16.230 : en:Chapter 40
02:13:27.583 : en:Chapter 41
02:16:57.250 : en:Chapter 42
02:19:19.809 : en:Chapter 43
02:27:34.011 : en:Chapter 44
