I thought I’ll share this because it happened on my 1080p tv wich was rock solid till today.
I was streaming something to Chromecast and had other hdmi port selected after swapping back to my vero tv is now in some odd resolution with huge black bars at the side and the colors are very off and dull. Rebooted multiple times but it didn’t fix the issue
You should be able to go to settings>system>display and set your UI back to 1080p which is not what it is set at currently. I don’t have an explanation for what happened. These logs were taken after you rebooted several times so don’t show the period of time where this happened, correct? Was this a one off event? If so, I doubt it is worth trying to figure out.
Manually setting the resolution back to 1080p works and also fixes the colors. You are correct I rebooted twice, once to see if a reboot will automatically fix my issue and once after that when I enabled the log
