I previously replied to another thread mentioning this issue but it’s persisting so hoping someone can spot something I’ve missed.
The only time I had this issue previously was when using a 2.4G wifi network, I’ve had no such issues running a 5Ghz network before this update.
The issue is that 1080p video stutters, it starts OK for a few seconds but then stutters as if the network connection has slowed right down. I’ve done an iperf test and all seems fine for a 5Ghz network (posted below), server is running Win 10 Pro, even did the checks with the Eset firewall turned off. No issues or errors thrown on the PC side, it’s running Hanewin NFS server and I’ve been using this for years.
Logs are here https://paste.osmc.tv/kaxocuraxe and I can see the sync drifting out after playback starts. I did the reboot twice. I’ve watched the CPU and nothing is being taxed there since acceleration is turned on.
Previous to the update there were no issues. 480p/576p video plays just fine. All my video is direct rips from my own collection.
osmc@osmclivingroom:~$ iperf3 -R -c 192.168.1.200
Connecting to host 192.168.1.200, port 5201
Reverse mode, remote host 192.168.1.200 is sending
[ 5] local 192.168.1.29 port 54540 connected to 192.168.1.200 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 13.4 MBytes 112 Mbits/sec
[ 5] 1.00-2.00 sec 12.4 MBytes 104 Mbits/sec
[ 5] 2.00-3.00 sec 13.4 MBytes 112 Mbits/sec
[ 5] 3.00-4.00 sec 12.7 MBytes 106 Mbits/sec
[ 5] 4.00-5.00 sec 13.3 MBytes 112 Mbits/sec
[ 5] 5.00-6.00 sec 13.0 MBytes 109 Mbits/sec
[ 5] 6.00-7.00 sec 13.3 MBytes 111 Mbits/sec
[ 5] 7.00-8.00 sec 13.9 MBytes 117 Mbits/sec
[ 5] 8.00-9.00 sec 12.8 MBytes 107 Mbits/sec
[ 5] 9.00-10.00 sec 14.0 MBytes 118 Mbits/sec
[ 5] 0.00-10.00 sec 132 MBytes 111 Mbits/sec sender
[ 5] 0.00-10.00 sec 132 MBytes 111 Mbits/sec receiver
iperf Done.
osmc@osmclivingroom:~$ iperf3 -c 192.168.1.200
[ 5] local 192.168.1.29 port 54544 connected to 192.168.1.200 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 16.2 MBytes 136 Mbits/sec 0 217 KBytes
[ 5] 1.00-2.00 sec 16.1 MBytes 135 Mbits/sec 0 217 KBytes
[ 5] 2.00-3.00 sec 13.6 MBytes 114 Mbits/sec 0 217 KBytes
[ 5] 3.00-4.00 sec 13.0 MBytes 109 Mbits/sec 0 217 KBytes
[ 5] 4.00-5.00 sec 13.6 MBytes 114 Mbits/sec 0 217 KBytes
[ 5] 5.00-6.00 sec 14.5 MBytes 122 Mbits/sec 0 217 KBytes
[ 5] 6.00-7.00 sec 14.4 MBytes 121 Mbits/sec 0 217 KBytes
[ 5] 7.00-8.00 sec 14.5 MBytes 121 Mbits/sec 0 217 KBytes
[ 5] 8.00-9.00 sec 14.9 MBytes 125 Mbits/sec 0 217 KBytes
[ 5] 9.00-10.00 sec 14.8 MBytes 124 Mbits/sec 0 217 KBytes
[ 5] 0.00-10.00 sec 146 MBytes 122 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 145 MBytes 122 Mbits/sec receiver
iperf Done.
Any thoughts? For info my second Vero 4K+ does exactly the same. I need to find a long enough network cable to see if anything funky is happening over wifi although iperf says not.
Many thanks,
Paul.
Probably an aside but I noticed the seek bar is at the top when playing 480p content?
I’m sure one of the OSMC guys will be along to help you shortly. In the meantime I suggest you post MediaInfo for one of the files that is having problems. You could perhaps also try playing it from the Vero’s flash storage, or from a USB stick or memory card - if it plays smoothly from there, that suggests a network problem; if it doesn’t, then maybe a decoding problem - either way it will narrow things down a bit.
Ahh yes, sorry I didn’t think as they worked previously: here’s the file plus a couple of others:
General
Unique ID : 249908250386179920111100027397389798087 (0xBC029409F30FB8A73D22B028D795CAC7)
Complete name : U:\tv series\maigret (2016)\season 01\maigret (2016) s01e01.mkv
Format : Matroska
Format version : Version 2
File size : 18.1 GiB
Duration : 1 h 26 min
Overall bit rate : 29.9 Mb/s
Movie name : Maigret
Encoded date : UTC 2018-10-11 20:50:12
Writing application : MakeMKV v1.12.3 win(x64-release)
Writing library : libmakemkv v1.12.3 (1.3.5/1.4.7) win(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 27.9 Mb/s
Maximum bit rate : 33.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Scan type, store method : Interleaved fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.538
Stream size : 16.8 GiB (93%)
Language : English
Default : No
Forced : No
Original source medium : Blu-ray
Audio
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate : 2 013 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Stream size : 1.21 GiB (7%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Text
ID in the original source medium : 4608 (0x1200)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 25 min
Bit rate : 36.3 kb/s
Count of elements : 2132
Stream size : 22.1 MiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:09:44.600 : en:Chapter 02
00:19:16.600 : en:Chapter 03
00:29:28.200 : en:Chapter 04
00:39:54.880 : en:Chapter 05
00:51:07.240 : en:Chapter 06
00:59:43.600 : en:Chapter 07
01:08:19.840 : en:Chapter 08
01:16:07.760 : en:Chapter 09
General
Unique ID : 842095567363374316827503463788685084 (0xA22E845847D349F7E39B84D9B7A71C)
Complete name : U:\tv series\lewis\season 09\lewis s09e01.mkv
Format : Matroska
File size : 9.90 GiB
Duration : 47 min 40 s
Overall bit rate : 29.7 Mb/s
Movie name : Inspector Lewis Series 8 Disc 1
Encoded date : UTC 2018-09-17 19:51:42
Video
Format : AVC
Duration : 47 min 39 s
Bit rate : 28.0 Mb/s
Maximum bit rate : 35.0 Mb/s
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.563
Stream size : 9.32 GiB (94%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 1 684 kb/s
Channel(s) : 2 channels
Channel layout : L R
Bit depth : 16 bits
Stream size : 574 MiB (6%)
Title : Stereo
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Duration : 46 min 49 s
Bit rate : 39.0 kb/s
Count of elements : 1764
Stream size : 13.1 MiB (0%)
Language : English
Default : No
Forced : No
Menu
00:13:14.126 : en:Chapter 02
00:24:17.747 : en:Chapter 03
00:36:58.007 : en:Chapter 04
General
Unique ID : 194766416466145296581670705645694854219 (0x9286A5B99A282982930975EA0071A44B)
Complete name : U:\tv series\miss marple\season 01\miss marple s01e01.mkv
Format : Matroska
Format version : Version 4
File size : 8.79 GiB
Duration : 53 min 42 s
Overall bit rate : 23.4 Mb/s
Movie name : Miss Marple: Volume 1 Disc 1
Encoded date : UTC 2015-02-19 19:01:29
Writing application : mkvmerge v7.3.0 ('Nouages') 64bit built on Oct 22 2014 18:53:34
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Video
Format : AVC
Format settings, GOP : M=3, N=12
Bit rate : 22.5 Mb/s
Maximum bit rate : 37.0 Mb/s
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.452
Stream size : 8.43 GiB (96%)
Language : English
Default : No
Forced : No
Audio
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 939 kb/s
Channel(s) : 1 channel
Channel layout : C
Bit depth : 16 bits
Stream size : 361 MiB (4%)
Title : Mono
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Muxing mode : zlib
Duration : 51 min 22 s
Bit rate : 15.6 kb/s
Count of elements : 1474
Stream size : 5.73 MiB (0%)
Language : English
Default : No
Forced : No
Menu
00:08:34.764 : en:Chapter 02
00:17:00.477 : en:Chapter 03
00:22:03.530 : en:Chapter 04
00:31:28.553 : en:Chapter 05
00:38:38.065 : en:Chapter 06
00:45:44.867 : en:Chapter 07
00:52:27.561 : en:Chapter 08
Does the issue go away if you play the file from local storage, i.e. a hard drive?
Sorry for the delay. I assume the network will be the issue but have just ordered a memory stick to check as I have none to check with.
So this turns out to be nothing to do with Kodi, the Vero or my network. Turns out it was Windows. No idea whether it’s Eset, Windows itself or something else but an update must’ve happened at the same time.
I was in the process of moving my fileserver to linux anyways, now that’s done, files are shared via NFS but finally sorted AutoFS and the same files play with any problems
