10bit 444 chroma?
Where do I set this option in Vero 4K
Will this fix the banding issues I see in 4K material?
It will indeed.
If you know how to use SSH, see 4k HDR too dim/dark - #14 by grahamh.
Otherwise, it will be fixed in the next update and you can just enable HDR Autoswitch in Kodi. Do not enable both however.
Ok thanks I Will wait. Btw what does the optimize HDR for outputs do?
It automatically switches the TV mode.
Ok my Samsung KS7000 series TV have no problem switching to HDR, so I guess I don’t need it.
