I just used the image for OSMC with 2 different SD cards on a RPi 2 & RPi 3… now both won’t even boot to the rainbow. (even with no SD card in them.)
Anyone else have this problem?
Anyone else fixed this problem?
Did you choose the right image?
Yes, I downloaded the latest for 2/3/3+…
I will try to download an older version, but I am worried that I can’t do anything because it won’t even boot now :-s.
Well if even an older Image fail than surely something is wrong.
Are you using the official installer to write the image to the SD Card?
I just had a look, I didn’t see that there. I went right for the download link at the bottom.
I haven’t installed anything until right after the RPi 3 just came out.
I used to use SDformatter and W32Diskimager, like we used to.
I will give that a go.
Oh my god, I thought they were dead.
That worked!
Thank you SOOOO much… my old man will be so happy too.
Thank you!
