Looks like I’m having a similar issue with a Vizio M601d-A3R connected through an Onkyo TX-SR607. I took an upgrade to OSMC on my RPi2 on 3/27/16 and CEC stopped working. I assumed there would be a fix out shortly, so I just used Yatse as a remote for the week. The upgrade yesterday 4/3/16 broke Yatse - no arrow functionality but I could still run volume and reboot it from Yatse. I searched for similar issues and found this thread.
The fix from the second post above:
fixed the CEC - which is good - but Yatse is still busted. Which is a real issue since I haven’t ever figured out how to get to the options menu from my Vizio remote/CEC.
Can I run this script to fix the above “issue” again?
The same issue is present on the latest July 31 release. Once the source is selected away from the TV to OSMC the surround system drops the speakers back to the TV. I then need to reset VieraLink to get the surround speakers back for anything.
Installed a freshJarvis install then restored a backup of my previous system so it didn’t have the CEC patch you provided.
Had issues with a continuous sad face bootloop. Got around this by renaming .kodi folder. Not sure what the issue is there…? Could it be because of me using Confluence skin?
After i updated to 2016-9-1 have several CEC issues with a Samsung Tv (Anynet+) and a soundbar by Yamaha.
Before the update everything was working flawlessly.
I notice CEC is very slow to connect which means that i’am not able to use my TV remote for 5 minutes.
Then when i switch source from HDMI 1 to TV it looks like CEC won’t switch because i still have acess to Kodi CEC menu when on TV source… i also have sound issues because the CEC-ARC is not displayed on TV.
When i go back to Kodi on HDMI 1 the amp does not show Kodi CEC menu anymore.
I triggered “connected to HDMI device” by changing Physical address… but it’s a no go
Btw i wonder why this option is not seen in the menu otherwise…
any help here ?
