Just updated to the 201.02-4 update and noticed that when the AV input is changed to OSMC on the Panasonic TV the surround system CEC is partially lost.
Setting to OSMC I lose control of the volume through the surround system and it defaults back to the TV speakers. The surround system volume remains stuck to where it was prior to changing the input source OSMC. I need to use VIERALink Tools to reset the Spaeker Selection to the surround system.
EDIT: Changing back to watch TV or across to the Apple TV reactivates the surround system volume and it works as it should. THIS IS NOT CORRECT - JUST TESTED AGAIN. CEC volume control of surround system is lost when changing back to other sources
No, I didnât say that it is expected behavior. I just canât see what is wrong with my change, it corresponds to the hdmi cec specification. I have tested with my Samsung TV, Denon AVR, Wetek Core and Play with OpenELEC and a Nvidia Shield TV. I canât see this problem.
Would you be happy to try some more builds? I can produce one with both above patches reverted but the @gda one re-added and you can let me know if the issue still persists.
On Sunday, Iâll be pushing an update with the new CEC library that affected you. It would be good if we could try and resolve that issue before Sunday.
Please try this build and let me know if CEC works normally. There will probably be two more builds to try (to bissect the offending patch).
You can wget the Deb and use dpkg -i to install it as before.
I donât understand what you mean by âpartial lossâ. If you want to wget the Deb directly, you will need to change dl=1 to avoid the HTML download page, otherwise SCP the Deb over.
With âpartial lossâ I mean that CEC control is still available and working ie; I can control OSMC via my Panasonic remote but the volume control of the Panasonic surround system is lost.
So I canât control the volume of the surround system anymore - it stays stuck on the current volume and volume control reverts to the TV itself. The only way to get the surround system volume control back is to re enable it via the Viera Tools button. Changing sources loses surround system volume control again.
This means that it is @gdaâs patch introducing this behaviour. Please replicate the issue from a clean boot with debug logging enabled from the start and post logs on our Pastebin
The patch does resolve a lot of CEC issues and for some users CEC does not work without it, so I am keen to keep it in for Sundayâs update
Itâs been pushed since Saturday and I havenât seen any reports of significant regressions so I am inclined to keep this in for now and provide this Dropbox binary as a fallback to those affected
