My Original remote started going bad, the “navigate left” button would not trigger… so wondering if there are any alternatives I can buy that would be compatible with the dongle? Like Amazon? Trying to avoid spending $30 US from the Vero shop for a replacement.
The Dongle would be 1:1 linked to a single remote so you could not use this dongle with any other remote. But normally you can use any 2.4 Ghz remote that comes then with it’s own dongle.
Instead of a simple remote you can also use wireless keyboards; I love my mini keyboard “Rii i8+ mini” which is the most used device to control my veros, here. Very handy if you need to quickly enter text e.g. you search for things in the mediacenter library, etc.
Ordered, thx for the suggestion
