Ah yes, you might be right. I do use a custom keyboard.xml but I can’t remember if I changed the behaviour for long press on the “Enter” key. If not, it will just fall back to the default…
Just to clarify, that’s what I was referring to in my original post. I have only been using Bluetooth… It was fine with the old version, now it’s not. @sam_nazarko FYI, just to clarify… I’m using Bluetooth, not IR. Not sure if that’s relevant difference or not, seeing lots of references here to IR/FLIRC.
Have you tried going into the device edit in harmony and setting the key repeat option to 0? I did this for mine and the problem went away.
Already set to zero, never been set higher. I’m using Bluetooth, not IR, so repeats shouldn’t be necessary.
