I just updated my 4K+ from the December version to the April version.
Generally everything is working okay (all videos play fine at the expected resolutions), however I have/had a few minor issues.
(self fixed) The screen resolution was set to 720p60 on first boot. I had it set to 1080p23.98. I changed this back to what I had it set at and it’s fine now.
(self fixed) The menu required a reset to defaults after upgrading, as two items in the top level menu came up as Not Found and Not Available. The menu reset fixed that. I didn’t think I customised anything in there.
(the most annoying, new bug in April not in December, not fixed) I use a Harmony Elite remote paired to my Vero 4K+. Since the April update, I’m now experiencing occasionally double inputs or input lag. What I mean by this is, when navigating the menu for example, say I’m scrolling down a list. If I press down once, I get a ‘click’ and it moves down one item. What is happening is that on a random number, either it doesn’t respond or I get multiple clicks in one go. This is not doing it fast or ‘repeat’, but rather separate, discrete button presses where I’m definitely only pressing the button once… but the Vero occasionally is now either missing it or interpreting it as more than one press. It’s mildly frustrating. I’ve tried rebooting, etc. and it won’t go away. It seems to be less bad once i’ve played a video file.
(ongoing from December build, not fixed) I still have a HDMI CEC issue where, if I enable CEC on the Vero, when I turn on my TV, receiver and another device (not the vero) the vero steals the input when coming out of standby. I have all the relevant options in the CEC settings turned off. The only way to stop this is to disable CEC on the Vero and leave it active all the time. With CEC enabled, I have it set to ‘suspend’ on TV power off. I’m not sure if this is caused by CEC being enabled, or the Vero coming out of standby and doing something at that point.
