I am having problems playing 2160p files.
If I start the movie from the beginning it’s fine. But if I try to forward it, click “resume from”, the box will either crash, get stuck on the ‘busy’ signal or takes several minutes before it plays.
Anything I can do about this please?
reproduce the issue
Does this only occur with the Resident Evil movie?
Did you restore your Kodi userdata from another device?
I can see a crash of your embuary skin, does your issue also happen when you’re using the OSMC skin?
2023-07-22 21:15:35.678 T:3473 error <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class 'AttributeError'>
Error Contents: 'datetime.timedelta' object has no attribute 'tzinfo'
File "/home/osmc/.kodi/addons/script.embuary.info/default.py", line 7, in <module>
from resources.lib.helper import *
File "/home/osmc/.kodi/addons/script.embuary.info/resources/lib/helper.py", line 15, in <module>
import arrow
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/__init__.py", line 2, in <module>
from .api import get, now, utcnow
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/api.py", line 12, in <module>
from arrow.arrow import TZ_EXPR, Arrow
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/arrow.py", line 1703, in <module>
Arrow.min = Arrow.fromdatetime(dt_datetime.min)
File "/home/osmc/.kodi/addons/script.module.arrow/lib/arrow/arrow.py", line 318, in fromdatetime
if dt.tzinfo is None:
AttributeError: 'datetime.timedelta' object has no attribute 'tzinfo'
-->End of Python script error report<--
I’ve only tried a small amount of 2160p as it always error’s, I thought I’d give it another try with the Rest Evil movie and 2160p is still giving problems.
The issue happens with both Metropolis and OSMC skins - I haven’t tried any others.
Can you try another HDMI cable?
I would suggest trying to reinstall OSMC. Nothing obvious sticks out to me in these logs.
