I have a 3-5 seconds black screen after opening MPEG-4/XVID/AVI video. Doesn’t matter if it’s the beginning or middle of the video, it shows a black screen, no sound, nothing. I can just jump back 10s to see what happened, but it’s quite annoying. I have (HW) Accelerate MPEG-2 and MPEG-4 set to “HD and up” in the Player Video settings.
Debug log: Kodi v20.2 on Vero 4K+ HDMI-CEC and AVI error - Pastebin.com at time around 21:57.
Mediainfo:
General
Complete name : video.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 351 MiB
Duration : 40 min 55 s
Overall bit rate : 1 198 kb/s
Writing application : VirtualDubMod 1.5.10.2 (build 2542/release)
Writing library : VirtualDubMod build 2542/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings : BVOP2
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Bit rate : 1 050 kb/s
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Original frame rate : 23.976 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.191
Stream size : 307 MiB (88%)
Writing library : XviD 57
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format settings : Joint stereo / MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Bit rate mode : Variable
Bit rate : 139 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 41.667 FPS (1152 SPF)
Stream size : 39.6 MiB (11%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.60 video frame)
Interleave, preload duration : 480 ms
Writing library : LAME3.97b
Encoding settings : -m j -V 4 -q 3 -lowpass 17 --abr 139
Is there any fix for this or is this the ARM license issue?
Thanks!
