Are the same three keys affected?
Stop key and go up volume down.
But if I’m not watching a movie, the volume up and down buttons work.
Thank you
Can you please upload a log so I can check this? It sounds like this may be software related.
How do I have to do?
Any idea of what is happening.
It’s not a debug log so I can’t see if the remote presses are being picked up; but I couldn’t reproduce this with my remote.
Does installing the 2018.12-1 version from Download - OSMC resolve the problem?
How can I upload a debug log?
With version 2018.12.1 if it works.
Thank you
reboot the OSMC device
reproduce the issue
upload the log set either using the
2019-04-28 19:19:30.383 T:4064772096 DEBUG: Keyboard: scancode: 0x9e, sym: 0x00a6, unicode: 0x0000, modifier: 0x0
2019-04-28 19:19:30.505 T:3787449056 DEBUG: Thread Timer 3787449056 terminating
2019-04-28 19:19:30.516 T:4064772096 DEBUG: Keyboard: scancode: 0x9e, sym: 0x00a6, unicode: 0x0000, modifier: 0x0
2019-04-28 19:19:30.517 T:4064772096 DEBUG: HandleKey: browser_back (0xf0b0) pressed, action is Back
The back button is being detected and handled.
the buttons that do not work are to raise and lower volume and stop.
The back button does work.
thank you
Are you using passthrough?
Can you try pressing the Stop button with the logs and play a file and try adjust volume?
Ok when I get home I try it
thank you very much for your help
https://paste.osmc.tv/ixiseriteh
Thank you
Thanks for the log.
VolumeUp is being detected:
2019-04-28 20:56:36.131 T:4039111392 DEBUG: CLibInputKeyboard::ProcessKey - using delay: 250ms repeat: 33ms
2019-04-28 20:56:36.131 T:3270165216 DEBUG: Thread Timer start, auto delete: false
2019-04-28 20:56:36.146 T:4069982208 DEBUG: Keyboard: scancode: 0x0d, sym: 0x003d, unicode: 0x003d, modifier: 0x0
2019-04-28 20:56:36.146 T:4069982208 DEBUG: HandleKey: equals (0xf03d) pressed, action is VolumeUp
But you have passthrough enabled.
We can’t control the volume (sometimes this is possible with CEC) or we wouldn’t be bitstreaming the audio.
Ok.
Thank you
Any advice for my case? It would be nice if you could also react on my previous posting here.
The May update changed nothing.
It’s possible we need to send you a new dongle.
Please open a support request by contacting support@osmc.tv.
The new dongle arrived today and the remote is fully working again now.
Thank you very much.
