Hi guys
I have a strange issue here, that I am assuming is due to the Vero 4k+ (but not 100% sure tho).
I have an Oppo 103D Blu-ray player that I use for 3d blu-ray discs. The player is just awesome and also has a nice video filter that aids in sharpening up 1080p video sources very nicely. The filter is in particular useful for 3d video, as it both sharpens and brightens up the image a bit. So, in order to take advantage of the Oppo filter also for my 3d isos on my Vero 4k+, I decided to route the Vero 4k+ through the Oppo 103D, which was a super success picture/videowise.
But audio, however, is an issue. And here is my problem: when playing 3d ISOs on the Vero 4k+, passed through HDMI on the Oppo 103D, no audio is being fed into my receiver from the Vero 4k+ in case the audio track is lossless (DTS Master or True DD), but PCM audio works fine (and some AC3 tracks).
Hmmm… ok, so my first suspicion was that there was too much data for the Oppo to process (when playing 3d and lossless audio together), but I quickly surrendered that idea. I tried running my ps4 through the Oppo, playing both MAD MAX and TRANSFORMERS Last Knight in 3d (both with Atmos tracks) and it played with no issues at all through the Oppo. Also tried some other discs with DTS or DD lossless and also played fine.
So, I am at a loss as to why my receiver is not getting fed the lossless audio from the Vero 4k+ when the Vero is passed through the Oppo (if the Vero 4k+ is plugged directly into the receiver everything works fine).
Note: When playing 2d film isos on the Vero 4k+, passed through the Oppo, the receiver gets the lossless audio just fine. So the issue seems to be limited to the combination of 3d video and lossless audio from the Vero 4k+.
Do you have any idea as to what may be causing this? My best guess is that there is some kind of handshaking issue between the Vero 4k+ and the Oppo, but that is very strange given that the video from the Vero passes through just fine (and that 2d + lossless passes through just fine).
Grateful for any help/suggestions.
Thanks.
