Using a Vero 4k+ set to 1080P resolution @ 60 frames.
The 3D gets turned on on the TV when I play 3D content, the notification pops up, but it looks like non 3D display would with HOU content. See attached.
The receiver supports 3D I’ve had it for years.
Does not do this when directly connected to the TV, I would like to keep it connected to the receiver to get PCM output.
Please post logs so we can see the content you are playing and if you have installed the 3D build.
I have installed the 3D build, last night.
Like I said it is working when connected directly to the TV, but when it goes through my receiver this is what happens.
I have a feeling this is a bandwidth limitation, or something the likes.
I will grab logs.
Log uploader is not working via GUi or bash.
osmc@osmc:~/.kodi/temp$ grab-logs -A
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/<html>
What logs do you need?
Log uploader is not working.
Don’t worry about it, it’s my receiver. Something happened to it after a firmware update a while ago.
I recall having this issue previously.
