Hi guys. I have a Vero 4k + running osmc kodi. My whitelist doesn’t show any more than 23.98hz and 24hz for 4096 x 2160. Is it a kodi limitation or is it my hdmi cable?
My sony bravia supports 50/60hz at this resolution
reproduce the issue
upload the log set (all configs and logs!) either using the
To upload a log seems very complicated to me and I don’t have an internet connection anyhow.
I would just like to know is if these resolutions are supported by the latest kodi version.
I know that there are only a few for 720p
My guess is you need to enable the higher mode on your TV, and/or use a HDMI input on the TV that supports higher modes (4k50/60)
How do I enable that on my screen?
I have no TV, I have a screen → 436M6VBPAB
It is supposed to make 3840 x 2160 @ 604 Hz? I thought it detected it automatically?
That depends on the maximum pixel rate (TMDS clock). You won’t see 3840x2160@50/60Hz if your screen can only do that with 8-bit, 4:2:0 output. What does cat /sys/class/amhdmitx/amhdmitx0/edid say?
Thanx for the suggestion grahamh
I have it on the right hdmi
I’m beginning to think kodi doesn’t do higher than 24p for 4096
I checked with the vero lead and an 8k 60 48mbps lead
In this thread from mid 2018 someone had the same problem
“When I set OSMC UI to 4096x2160p, why does it only offer 24hz and 23.98hz and not all the refresh rates reported by disp_cap? i.e. 2160p25hz, 2160p30hz and 2160p50hz”
Hmm. Which value you need?
$ cat /sys/class/amhdmitx/amhdmitx0/edid
Rx Manufacturer Name: DON
Rx Product Code: 0069
Rx Serial Number: 01010101
Rx Product Name: DENON-AVR
Manufacture Week: 0
Manufacture Year: 2020
Physical size(cm): 94 x 53
EDID Version: 1.3
EDID block number: 0x1
blk0 chksum: 0xde
Source Physical Address[a.b.c.d]: 1.4.0.0
YCC support 0x03, VIC (native 16):
ColorDeepSupport 0xb8 10/12/16/Y444 1/1/0/1
16 4 3 31 19 1 18 93 94 95 96 97 2 5 6 7 17 20 21 22 95 94 93
Audio {format, channel, freq, cce}
{1, 7, 0x7f, 0x07}
{7, 5, 0x1e, 0xc0}
{2, 5, 0x07, 0x50}
{11, 7, 0x7e, 0x03}
{10, 7, 0x06, 0x03}
{12, 7, 0x7e, 0x03}
{11, 7, 0x7e, 0x01}
Speaker Allocation: 0x5f
Vendor: 0x000c03 (HDMI device)
MaxTMDSClock1 300 MHz
Vendor2: 0xc45dd8
MaxTMDSClock2 600 MHz
vLatency: Invalid/Unknown
aLatency: Invalid/Unknown
i_vLatency: Invalid/Unknown
i_aLatency: Invalid/Unknown
Colorimetry: 0xc3
SCDC: 1
RR_Cap: 0
LTE_340M_Scramble: 0
HDR DeepColor
checkvalue: 0xde3a0000
So it is the AVR it is showing there.
The screen can definitely do more. The AVR should also not prevent something faster than the 30Hz
I used my roomates wi-fi and followed your instructions
Here are my logs
Edit: log taken off because it has ip address, for privacy
That’s all good. Those modes in the 90s are 4k and your TMDS clock goes up to 600MHz. Normally, if the higher HDMI modes are switchable on the display the EDID changes accordingly, but it’s still possible something needs setting on the display. Could you upload full debug logs, please?
Please look at my logs also grahamh
Last time I looked I was getting both 3840 and 4096x2160 at 50 and 60Hz. That log shows you should get 4096x2160 (‘smpte’) at 24, 50 and 60Hz but you are right - Kodi isn’t recognizing them.
We’ll look into it. But you won’t find much content with that resolution and refresh rate.
Please look into it. Thank you
I just checked, and I can’t get 4096x2160 at 50/60Hz either. Can’t get 25 or 30Hz either (which my TV supports). That must be new. Maybe Kodi devs decided no-one should be using that mode.
Is it important for you?
Hi, thank you for checking. It’s not important if it’s not supported in kodi. As you said its not very popular for content
These are SMPTE modes and they shouldn’t be used for playback.
I thought they capped out at lower refresh rates anyway.
You shouldn’t use these modes for the UI or for playback.
I actually don’t need it. Just wondered and wanted to participate in the thread, as I was also “impacted” technically speaking.
If you guys want to troubleshoot it, let me know. I am yet to find a movie using a higher framerate to see if it makes a difference though, and for creating the logs.
