For 1080p and below, output from the Vero 4K seems to be in YUV 4:4:4 format.
Is it possible to get it to output YUV 4:2:2 or 4:2:0 instead?
echo 422 | sudo tee /sys/class/amhdmitx/amhdmitx0/attr
420 is supported only for 4k50/60
I guess that won’t survive a reboot…? If I wanted to make it more permanent, could I?
Are there any situations in which making it permanent might cause problems?
To make it ‘permanent’ put that line in rc.local. I can’t guarantee it will not be overridden, though. Apart from 10-bit, we don’t use 422 because it’s a complete waste of time.
Similarly, I’ve no idea what problems it might cause - we don’t support it.
Doesn’t that depend on the relative merits of the chroma upsampling algorithms being used? (I’ll grant you, 4:2:0 would be preferable to 4:2:2 if it were an option at lower resolutions).
Although this doesn’t apply to me, in cases where a TV has HDMI inputs that are borderline out-of-spec, one might also find it slightly easier to get a stable connection with 4:2:2.
Well, anyway, you answered my question. ![]()
