I am fairly sure this used to work, but recently appears to have stopped working
I have my Vero4k connected via HDMI to a Denon AVR X2400H
If I set the ‘HDMI mode’ to enhanced on my amp (this is the setting to enable 10bit support on the amp), then ANY content I play from the Vero results in a black screen. I know the content is still playing, because I can see (via the Kodi remote app on my phone) that the film timer is running. If I use the app to stop playback, the Kodi GUI returns
If I turn off ‘enhanced mode’, then the Vero is happy to out put everything at 8bit
I have a SKY Q box which is quite happy to do 4k 10-bit (with the appropriate setting on the Denon amp)
I have also got a failed blue LED (I am aware this is a known issue) but whilst troubleshooting this, I replaced the power supply twice, so I am fairly confident this isnt a power issue
I have also replaced the HDMI cables, tried different HDMI inputs on the Denon (including the one with the working SKY Q box on). I have also connected directly to the TV with no success
One other strange issue with the Vero - it seems to hold open the HDMI in a very strange way, which randomly prevents any other HDMI device connected to the amp from working. If I unplug the HDMI cable from the Vero, then other devices can successfully handshake
EG - If I watch a movie on the Vero, then attempt to switch sources back to the Sky Q box - all I get is a black screen, forcing me to reboot the SKY Q box. This only happen immediately after using Vero
This never EVER happens after switching from PS4, Blu-Ray player or ARC
Also, if I switch from an input source to an ARC source (eg, Netflix on my LG TV), there is no sound until I unplug the HDMI from the Vero
Is it goosed?
I will upload some logs shortly, but has anyone else seen anything like this? I realise there may be two separate issues here, but it feels like they may be related in some way, as they are both broadly HDMI type issues
