thobu
22 June 2018 17:27
1
it worked for half a year and all of a sudden it doesn’t find the HDD. I checked the HDD it works normally on my Linux Mint box. Everything is there,
I’m on v1 June 2018
My log: http://paste.osmc.tv/gezininipa
At the same time I figured that SSH connection stopped working too.
I rebooted several times, unplugged USB hub and HDD already
Any ideas?
Jun 22 19:15:14 osmc kernel: usb 1-1.1: USB disconnect, device number 4
Jun 22 19:15:14 osmc kernel: sd 0:0:0:0: [sda] READ CAPACITY failed
Jun 22 19:15:14 osmc kernel: Result: hostbyte=0x01 driverbyte=0x00
Jun 22 19:15:14 osmc kernel: sd 0:0:0:0: [sda] Sense not available.
Jun 22 19:15:14 osmc kernel: sd 0:0:0:0: [sda] Write Protect is off
Jun 22 19:15:14 osmc kernel: sd 0:0:0:0: [sda] Mode Sense: 2e 2e 2f 2e
Jun 22 19:15:14 osmc kernel: sd 0:0:0:0: [sda] No Caching mode page found
Jun 22 19:15:14 osmc kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jun 22 19:15:14 osmc kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Is the disk externally powered?
Either there is a fault with the drive or it’s not getting enough power to spin up.
thobu
22 June 2018 17:34
3
the HDD works perfectly fine on my PC, I can play any file.
And yes, the disk is powered externally since many months now. I never had an issue…
thobu
22 June 2018 17:38
4
ah, and there’s this sound coming of the HDD, if they vero can’t find a path. I’ll check if the power supply broke.
thobu
22 June 2018 17:43
5
it came back after i unplugged the HDD from the externally powered hub and the hub from the vero several times. Strange.
I’d backup your data if it is important.
