Is the drive self powered, or powered via USB. If itâs powered via USB it is probably starving for power. Try using a powered USB hub instead of powering it from the Vero, as it can only supply the .5A max as per the USB spec.
This might be relevant. From the mount(8) man page:
Note that mount(8) uses UUIDs as strings. The UUIDs from the command line or from fstab(5) are not converted to internal binary representation. The string representation of the UUID should be based on lower case characters.
Changed to lowercase - now the drive shows in auto-mounted drives, but not in library (via mountpoint).
Fresh messages: https://paste.osmc.tv/kiyedulusa
It should be user, not users. That said, itâs unnecessary to use user in OSMC since you can always run sudo when mounting. (Just a FYI: default options are rw, suid, dev, exec, auto, nouser and async)
It might also have contributed to this permission-related problem:
Nov 09 18:13:16 osmc udisks-glue[437]: Failed to automount /dev/sda5: Error mounting: mount exited with exit code 1: helper failed with:
Nov 09 18:13:16 osmc udisks-glue[437]: Error opening read-only '/dev/sda5': Permission denied
Nov 09 18:13:16 osmc udisks-glue[437]: Failed to mount '/dev/sda5': Permission denied
Nov 09 18:13:16 osmc udisks-glue[437]: Please check '/dev/sda5' and the ntfs-3g binary permissions,
Nov 09 18:13:16 osmc udisks-glue[437]: and the mounting user ID. More explanation is provided at
Nov 09 18:13:16 osmc udisks-glue[437]: http://tuxera.com/community/ntfs-3g-faq/#unprivileged
