Hi friends
I’ve been trying to play a 4K HEVC HDR10+ file and it seems to show up only on a quarter of the TV’s screen. A sample file can be fetched in the kodi samples, number 9 of 4K (UltraHD) Formats - Kodi samples.
Whilst this happens when the player is set to adjust display refresh rate, if the UI is set to 4K then the file uses the full screen as expected. It’d seem connected with the adjustment of the display from 1080p UI to 4K. Other 4K videos play fine but this format uses only a quarter of the screen.
Does this file play in the TV’s whole screen for you? I’m not discounting that the TV’s firmware could be buggy (Sony X90J).
