After scraping, movies and TV shows (mostly mkv format) show up fine…but songs within folders do not? Artist folder + album folder shows up, but no tracks within album folder? What am I missing? Songs are in FLAC format…
After you added the Music source, did you set it to Music? Are your FLAC files properly tagged?
Of course, logs may help us. Make sure you run a scan before posting the logs.
reboot the OSMC device
reproduce the issue
upload the log set either using the
You log was empty. Reboot the Vero, run another scan and post logs again please.
I believe I finally figured it out…It had to do with the “change action” path I had chosen for the MUSIC main menu customization in OSMC skin. Thank you for your time and patience with a noob!
