Having issues with new update - it’s Buffering and the movies are from some slow to superslow (depends less on 1080, then worst to HEVC/4k) - this was same problem with 2 updates or so ago …pls test your updates 1st!
reproduce the issue
upload the log set (all configs and logs!) either using the
Updates are tested thoroughly and undergo rigorous testing. The last few updates have been well received
Please provide some logs as advised by Tom so that we can solve this promptly for you
Here’s that log - https://paste.osmc.tv/iretukaqop
in the meantime, is there a way to go back to 19.1 or .2 (last version)? the download page seems empty
Problem is still there after all sort of reboots, pull plugs all connected devices etc …
playing movies it says movie buffering and everything runs slow or freezes up but audio is still good
You have wired and wireless activated at the same time with an IP in your LAN. Suggest to disable wireless.
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 10.0.0.169 netmask 255.255.255.0 broadcast 10.0.0.255
ether 90:0e:b3:3b:9d:e5 txqueuelen 1000 (Ethernet)
RX packets 2465 bytes 2701786 (2.5 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 813 bytes 118127 (115.3 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 30
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 43 bytes 6109 (5.9 KiB)
TX packets 43 bytes 6109 (5.9 KiB)
wlan0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 10.0.0.187 netmask 255.255.255.0 broadcast 10.0.0.255
ether b0:02:47:f3:da:4f txqueuelen 1000 (Ethernet)
RX packets 356 bytes 43073 (42.0 KiB)
RX errors 0 dropped 1 overruns 0 frame 0
TX packets 86 bytes 15698 (15.3 KiB)
“You have wired and wireless activated at the same time with an IP in your LAN. Suggest to disable wireless.”
it was but I run an old backup settings in hopes that would work, didn’t and thanks
So switching wireless off solved your problem?
Found an old usb and just reinstalled!
So your problem was solved by downgrading? Did you go back to 19.1 or .2?
I suspect your issue is not related – please open a new post.
sorry for late reply, frankly I didn’t check and I just didn’t noticed what version the installer installed since it worked and I disabled all updates (before every other update brought problems so I figured I don’t have time for that and just disabled auto update)
