5ghz WiFi adapter recommendation?
I am looking for an 802.11 adapter in the 5ghz frequency range for my new Pi2 running OSMC. I would prefer it to be compatible with all three 5ghz standards (A / AC / N).
So far, I’ve been looking at these models, but am open to suggestions:
  • TP-LINK Archer T2U
  • TP-LINK Archer T2UH
  • TRENDnet TEW-804UB
Anyone care to weigh in? Amazon Prime day is coming up, and I’m eager to make a purchase!
Thanks in advance
DBMandrake did some tests on some here:
There are more recommendations if you scroll down.
Much of that thread seems to be focused on RC1/RC2/RC3. The option I chose during install was “2015.06-1”
Really, I was just hoping for folks using 5ghz wifi to pop in and say, “I use device xyz and it works great” or “stay away from abc, it sucks”
