Quite. Fix looks trivial – remind me in a couple of days when you’re back and I’ll send a patch through for you to test.
The kernel version, if fairly recent: i.e. post multi-channel audio implementation; will not make a difference. It’s a bug we introduced when fixing USB audio output in Kodi.
Actually, it was a workaround for a bug in the kernel which we inadvertently by-passed while fixing USB audio.
I get the same results. It works when the output device is set to PCM.
