just installed the April update and checked the settings.
While doing so, I realized that the audio I stream via my USB-Audio (Devialet expert) is downsampled when playing high res audio. 44.1 and 48 kHz is playing correctly. 96khz is downsampled to 48khz.
Is there something I can change? Right now, the sampling is set to “best fit”.
Best regards
Andreas
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
You will probably have two USB dacs in your audio settings - Make sure you have the dacname,SPDIF selected the dacname,analogue is limited to 48KHz .
