Clearly, there’s a sequence of events at system startup and, for example, some processes will need a network connection before starting. Systemd has complicated the picture a little because it can run things in parallel, giving the potential for “race conditions” to occur. As a result, systemd gives us the ability to control startup sequence with After=, Before=, Wants=, Requires= and so on.
So I guess the answer to your question “Is that correct?” is yes, since you’ve (re)defined a startup sequence that better meets your set-up.
