Last question, I promise…
Now that this is in place when I shutdown or reboot, it hangs with this line:
a stop job is running for /mnt/SambaUsb (1min30)
Is there a way around this?
EDIT: ok so basically since I am on a share via WLAN , the network is shut down before it can unmount. So I don’t see a real solution. However, is there a way to reduce the time value (1min30)? That way it would be less of an annoyance…
EDIT 2 : I’ve tried to add _netdev but it seems it is not working either
Ok, moved it to a new topic as I don’t think it is related to your original question and might have others impacted. @ActionA, @DBMandrake, @sam_nazarko
Maybe you can do some testing on your side but for what I found I can confirm that when on wireless network and having a samba mount when you shutdown/reboot you get “a stop job is running” for the samba unmount.
This only happens when on wireless when I use wired on the same machine it shutsdown cleanly.
My fstab is //osmc.my.hk/128G_video /mnt/osmc.my.hk cifs x-systemd.automount,noauto,iocharset=utf8,user,credentials=/home/osmc/.osmc.my.hk.smb,uid=osmc,gid=osmc,iocharset=utf8,file_mode=0770,dir_mode=0770 0 0
The problem appears also only on a wireless connection in my case.
my fstab is : //192.168.1.41/Torrents /mnt/SambaUsb cifs noauto,x-systemd.automount,username=osmc,password=osmc 0 0
Ok thank you ! To check that this is also the case with NFS I’ve set it up (fstab entry = 192.168.1.41:/export/Torrents /mnt/Nusb nfs noauto,x-systemd.automount,soft,tcp 0 0). I also get a stop job is running error at reboot for that particular mount.
I’ve been thinking… Could I somewhere add a line that makes the network share unmount when I click on rebooting (before actual shutdown takes place) ? Sorry if the question is dumb…
Well I’ve found a workaround, for my dual boot anyways. I have just added :
os.system(sudo umount /mnt/Nusb) , before the reboot line of the launcher I used for recalbox (thanks MattHuisman for the launcher) .
It works.
Obviously I still have the problem when I simply reboot OSMC.
A long shot idea might be to add an OSMC GUI setting to add network shares (which would add it to fstab, on a predefined pathname) . This way this could automatically add an umount “predefinedpathame” before the shutdown sequence. At the same time, it would make OSMC more userfriendly when it comes to network share (since os mounting is way faster than kodi access).
