Everything had been fine for over a year with this setup. I had my entire system disassembled for the first time since successfully putting it together a year prior the other day. Now, when playing movies with 5.1 DTS/Dolby audio streams, dialogue is absent. I plugged my HDD movie source directly into the TV’s usb input and am able to get the dialogue stream from every audio track on any of my .mkv’s while playing through the TV’s (TV itself is capable of playing .mkv’s).
Not sure what could be causing this. 2.0 channel audio tracks play with dialogue, but 5.1 channel audio tracks do not.
Appreciate your help!
Alll devices are plugged via hdmi into a ‘samsung one connect’ cable and toslink cable from the one connect to the audio reciever. So essentially, the OSMC device is outputting audio via HDMI to the TV which is then outputting audio via optical to the receiver.
Please read this post about correctly setting up your audio.
Also to get a better understanding of the problem you are experiencing we need more information from you. The best way to get this information is for you to upload logs that demonstrate your problem. You can learn more about how to submit a useful support request here.
reproduce the issue
