ok so i wanted to gather a list of items people have updated their atv1’s with, as well as a part # listing so us others who have not upgraded anything yet can in the distant (this weekend future!!
ok so i see people who have upgraded to the crystal card, and i do believe there is a newest version right?
part #-cost?
benefits of this card?
it doesnt allow wifi does it?
also is an ssd worth it, or would a internal micro card be a better cost worthy addition?
is there a certain speed and or size best for either an ssd or internal micro card?
any others you guys have added such as:
usb hub?
external harddrive?
let us know so we can all upgrade these as much as possible!
I’m a total newby who could use that info too…I just purchased an Apple TV First Gen and want to get it going with Kodi. I’m currently using a 2nd generation ATV but it crashes all the time.
I’m hoping for somebody to do a step by step YouTube Video for ATV1 upgrade to OSMC (for dummies…lol) From start to finish, everything one needs to do.
Was wondering what kind of external card I’ll need for the ATV1,The exact model number would be helpful.
I too am worried about WiFi…I don’t have a modem in my living room to hardwire it.
I think I saw a video on how to install the 1080P card and it looks fairly straight forward, but do you lose Wifi with that card? I might just stick with my 1080i picture.
Hey guys! So i’ve been working on my ATV1 for a few months now (since I found it in a box in my garage) and i’ve done some stuff to it but nothing too exciting. I always get frustrated when things are going slow and I cant help but want to figure out how to solder more memory and cut out that CPU and build a new one lol! but then when things are working well i feel pretty proud.
anyway, the IDE cable from foxcomm became really brittle and finally gave on me this weekend. I’m trying to figure out if its possible to connect to devices to that one i.e. the pata drive as well as a dvd± rewritable i have lying around. I looked into whether the pata port would support a miniPCIe slot but that didnt get too far. Before I got into this project I didnt really know much about components; I’m learning a lot and definitely enjoying it haha. Sometimes its hard to get a question answered for whatever reason but actually come across a lot of people in these forums that have been very helpful! thanks guys!. That said, I really really wish the ATV 1 had two minipcie’s or atleast an msata but there’s still plenty that we can figure out haha. .
alright so lastly, I was looking around inside the console the other day and i noticed a black 4 prong port. I’ve looked everywhere online and haven’t found a clear answer does anyone know? I included a picture here so u can check it out. It looks like it could be either a fan plug, small sata power supply (kinda) maaaaybe usb or audio. I plugged a small speaker into it the other day and it melted so its not audio and its definitely not 3.3v and I wont tell you how I came to that conclusion so all thats left are the
Hi friend, my small contribution to your post, I like you want to change, or update ie: memory, cpu etc, but those that know tell me that it’s impossible , they told me you could not install two drives into the ATV1, you can, there must be a way to install more Ram, but of course the software would have to changed to allow this to happen, but please there must be someone out there that know’s what we need to do, *ANY IDEAS PLEASE POST"
Hi my friend,
these were pictures I took, this was my project, I have 4 ATV1s and each one has a different configuration, this is where I get my pleasure, taking things apart and rebuilding, not so worried about what happens after. If there’s something particular you’d like to know about upgrading your device, fire away my friend, always willing to help out.
man id love to see what u did to each appletv! also would love a parts list for the ssd build… could u do a step by step tutorial or even a video perhaps? even tho these are old, id love to see what exactly they are capable of especially since i do believe they can last for a very long time, only hard part is the coding of software towards these in the future as the have limitations…
Ok friend, firstly will set out what you need to do a simple Ide to SSD conversion, this will include pics of the required parts, adapters etc, I’ll try and do it one day next week, I will make a video in the very near future starting with an untouched ATV1 and progressing through to the final Configuration, the pictures you’ve already seen show the box in a Dual Drive configuration, but to be honest I only build this to prove that I could, it’s better with a slimmer config, ie: a small 30GB Msata SSD on a Ide 44pin adapter. then for backups and downloads use a USB SSD drive in the USB Slot.
This is about the fastest working ATV1 you can get. The only stuff that’s out of my pay scale is the coding etc, I have to leave this stuff up to Sam and the rest of their hard working team, I never ever learned that stuff, it goes straight over my head.
yes man! this is amazing well I decided to go with an external drive and I also have an external dvd-r drive i’m going to use to import all of my old cd’s. I’ve noticed my drive response is a bit faster with an external drive though.
where did you get that 44 pin dual drive flat cable? I’ve looked for them EVERYWHERE but cant seem to find them. I ordered two and they were both the bigger 3.5 ide.?? I’d really like to invest in a decent size ssd to get rid of moving parts and bring down the unit temp. I run a little hidden fan over it and i’ve noticed it keeps the top (where the gpu touches the case) that it keeps a little cooler. Things are a little more responsive when not as hot.
Is it guaranteed to work 100% without having to SSH and install stuff ?
Does it connect back to Wifi network after you unplug then plug it back again ?
