I tried many combinations with buffering in advancedsettings.xml also audio passthrough doesn’t help. The videos where the issue occurs seem to be encoded with AAC. These issues happen on plugins that use Live Streams from the internet (namely ncplusgo and Playermb). Playing video from the SD card works fine.
I also did apt update && apt upgrade-distro. I’m running the current OSMC version.
I hope you could help. I saw some post with this issue but it seems unresolved.
Without logs one can only speculate but more often than not the large audio sync errors are a configuration issue with refresh rate. The stream stalled is normally a networking issue or lack of bandwidth.
reproduce the issue
Thanks for your help.
In the end it turned out to be a problem with my router. Somehow when the DNS on RPi3 is set to the IP of the router, everything is lagging. When I change it to 1.1.1.1 or anything else, it starts to works flawlessly.
For those reading that in the future, to change it I used:
