I subscribe to a website that offers VOD.
Can I add the “Direct M3U URL” to Vero to play the movies?
If so How?
If so How?
You can add it using the IPTV Simple add-on
I’m looking under “Add-ons” and can’t seem to find it.
Go to add-ons>my add-ons>PVR clients>PVR IPTV Simple Client
Enable it, go to ‘configure’, change "location’ to ‘local path’ and then choose the file with ‘M3U playlist path’, then click OK. You will need to reboot kodi once this is done.
Thanks for the info. Working fine.
