How do I install autofs to do this and add my google drive files?
You would need a FUSE helper to do use Google Drive with fstab/autofs.
http://gdfuse.forge.ocamlcore.org/ looks like it may work.
I use another PC and rclone mount my Google Drive with the SYSTEM user using Task Scheduler, and then share the mount via SMB. OSMC then uses that mount as an fstab mount.
I’m not sure why the forum thinks this body is too similar.
