Hello,
I’m using an xbox360 pad on osmc, but when i synchronise it, the four led keep blinking.
It’s because JOYSTICK_XPAD_LEDS is not set, is it possible to add it by default if there is no side effect with other controler ? (so we won’t have to rebuild the kernel at each upgrade to use it ^^’ )
Best regards !
What device are you using?
Hello,
I’m on raspberry pi 3 with kernel rbp2-image-4.19.55-3-osmc
osmc@rpihtpc:~$ cat /etc/debian_version
9.9
osmc@rpihtpc:~$ cat /boot/config-4.19.55-3-osmc |grep XPAD
CONFIG_JOYSTICK_XPAD=m
CONFIG_JOYSTICK_XPAD_FF=y
# CONFIG_JOYSTICK_XPAD_LEDS is not set
# CONFIG_JOYSTICK_PSXPAD_SPI is not set
I’m happy to accept a PR for this
