Would like to add a new subtitle font to kodi (I only have arial and teletext). What would be the easiest way in Vero4K?
Thanks a lot!
Ruben
Thanks a lot!
Ruben
Based on this http://kodi.wiki/view/Subtitles
It should go into /home/osmc/.kodi/userdata/Kodi/media/Fonts/ even so this seems to be quite strange.
This might just be written badly alternatively I would try /home/osmc/.kodi/media/Fonts/
Do I need a PC to do that? A bluetooth keyboard would be enough? Is there a simpler way to do it?
Thanks!
Ruben
There is an article on OSMC Wiki page on accessing the command line.
Well, I am a little bit lost with adding the sub fonts to osmc… Will you have an easy, step-by-step, link to a guide on how to to do it?
Thanks a lot!
Ruben
You need to copy .ttf file of the font you want to use to:
Thanks Tom.
Solved!
Thank you!!
Ruben
Hello,
I’d like to add fonts to my vero 4K+. I tried to copy the .ttf files to the folder /usr/share/Kodi/media/Fonts/ and it didn’t work.
So I searched for this topic and go to the solution. The folder didn’t exist so I used FileZilla to navigate into my Vero 4K+ and create it and then I copied all the fonts I wanted to the folder /home/osmc/.kodi/media/Fonts/ and it finally works !!
Thanks for this usefull topic.
