Add USB hub to Vero 4k+
I have a single usb HDD attached to my vero 4k+, can I use one of these to attach more than one ?
Yes
Thanks, tried a couple of other USB hubs and it was not happy !
Where they “powered”?
How many disks did you attached?
What was the current for the drives?
One was powerd on was not, but if £15 on this one will definetley do the job I shall just get one, just wanted to check.
All 3 of the HDDs are 2.5 inch, usb, Toshiba, 2 x500 gig, 1 x 1tb
That should work while it could be at the edge when powering up. Normally the drives take up to 600 - 800mah which with 3 disks would be at the edge of the 2A from the powersupply of the powered hub. But I assume 3 drives will work
Really helpful thanks, I only really need 2 HDDS plugged so will get one.
