Add wifi credentials to vero 4k via SSH or MicroSD
Hello,
Much like a raspberry pi is it possible to create a file somewhere with my wifi connection details so it boots and connects to my wireless network?
Failing that, what is the command line tool used to set the wifi connection?
connmanctl
It’s not possible currently but you could do it via the command line.
If there’s demand we could update the installer to support this.
Thank you both for the quick reply. No need to implement such a niche feature however.
