I did a search for this and found a few close-but-no-cigars – had a single RP/OSMC build hanging off a Win7/XBMC build and all was fine. I added a second RP/OSMC build with its own name and whatnot, seemed to be working fine except now Live TV hangs on all three devices – can’t change channels without rebooting. I’m using ServerWMC, and a Ceton InfiniTV 4-tuner card.
Anything obvious I can check before posting logs?
Thanks in advance!
OK, I’ll send a log but it’ll probably be after New Years. Thanks for the prompt reply.
Had some fun, and lo and behold this particular issue sorted itself out.
Thanks for the responses.
