I am trying to add my own menu entry by compilation (not by gui).
So far, I have downloaded the OSMC sources and the filesystem tar. I added a copy the “My OSMC” entry in skin.osmc/16x9/script-skinshortcuts-static.xml file as the 15th (and last) entry and renamed it. I compiled the code, flashed it, and put it on a rbp3. I see my entry in the menu.
When leave the Runscript(service.osmc.settings)<\on click> the “My OSMC” menu opens. But when I redirect it to another location Runscript(/usr/shar/kodi/addons/script.hello.world)<\on click> I keep seeing in the log:
16:56:42.953 T:1958539264 ERROR: ExecuteAsync - Not executing non-existing script /usr/share/kodi/addons/script.hello.world
In the script.hello.world I have an addon.xml file.
I am not sure where I can find information of how to initialize the labels of my entry in the script-skinshortcuts-static.xml file.
Can you please post the output of the following commands?
ls -lah /usr/share/kodi/addons/script.hello.world
cat /usr/share/kodi/addons/script.hello.world
Hi yknivag,
osmc@osmc:~$ ls -lah /usr/share/kodi/addons/script.hello.world
total 48K
drwxr-xr-x 3 root root 4.0K Jan 1 1970 .
drwxr-xr-x 159 root root 12K Jan 1 1970 ..
-rw-r--r-- 1 root root 146 Dec 12 11:07 README
-rw-r--r-- 1 root root 778 Dec 18 13:44 addon.xml
-rw-r--r-- 1 root root 0 Dec 12 11:07 changelog.txt
-rw-r--r-- 1 root root 650 Dec 12 11:07 default.py
drwxr-xr-x 5 root root 4.0K Jan 1 1970 resources
-rw-r--r-- 1 root root 1.2K Dec 12 11:07 service.py
-rw-r--r-- 1 root root 11K Dec 12 11:15 xxx_logo_3-300x76.png
osmc@osmc:~$ cat /usr/share/kodi/addons/script.hello.world
cat: /usr/share/kodi/addons/script.hello.world: Is a directory
It seems you are trying to execute a directory. But then that could just be a poor kodi error message.
There also seem to be problems with the permissions on that directory. Try setting the directory you created and all files in it as owned by the user osmc:
sudo chown -R osmc:osmc /usr/share/kodi/addons/script.hello.world
And it may not be a bad idea to set the executable bit on the python files:
chmod a+x /usr/share/kodi/addons/script.hello.world/*.py
If I am not mistaken, this is how it’s supposed to be done. the directory should have an addon.xml file inside which will point to the python script.
Changing owner did not work. still see the same log.
I don’t think this is the issue since ls -al on service.osmc.settings shows the same permissions:
osmc@osmc:~$ ls -la /usr/share/kodi/addons/service.osmc.settings/
total 140
drwxr-xr-x 3 osmc osmc 4096 Jan 1 1970 .
drwxr-xr-x 159 root root 12288 Jan 1 1970 ..
-rw-r--r-- 1 osmc osmc 146 Oct 24 13:42 README
-rw-r--r-- 1 osmc osmc 865 Oct 24 13:42 addon.xml
-rw-r--r-- 1 osmc osmc 0 Oct 24 13:42 changelog.txt
-rw-r--r-- 1 osmc osmc 650 Oct 24 13:42 default.py
-rw-r--r-- 1 osmc osmc 89468 Oct 24 13:42 fanart.jpg
-rw-r--r-- 1 osmc osmc 14378 Oct 24 13:42 icon.png
drwxr-xr-x 5 osmc osmc 4096 Jan 1 1970 resources
-rw-r--r-- 1 osmc osmc 1168 Oct 24 13:42 service.py
I think I am missing some type of registration of my addon somewhere…
This is more a Kodi issue than an OSMC specific one. Have you also tried asking there?
The error definitely suggests that kodi cannot see the file it wants to execute. Are you sure your addon.xml file contains the correct names for the python scripts?
