Adding missing Perl libraries to OSMC
Is there a way to add some missing Perl libraries to the osmc build?
I did some searching and saw where you shouldn’t do the standard Perl install with most of the debian based distros.
Thanks in advance
Perl is already installed.
You should be able to install additional libraries as you would with Debian
