I can’t install addons because it says no connection possible. The addons I installed before upgrading to krypton are still there but don’t work. How can I fix this? I have a RPI 3.
[details=Summary] 11:42:03 10.857992 T:1958237104 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:42:03 10.858143 T:1958237104 NOTICE: -----------------------------------------------------------------------
11:42:03 10.858191 T:1958237104 NOTICE: Starting Kodi (17.0-BETA5). Platform: Linux ARM (Thumb) 32-bit
11:42:03 10.858227 T:1958237104 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
11:42:03 10.858266 T:1958237104 NOTICE: Kodi compiled Oct 31 2016 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.36 (200740)
11:42:03 10.858518 T:1958237104 NOTICE: Running on Open Source Media Center 2016.10-2, kernel: Linux ARM 32-bit version 4.4.27-2-osmc
11:42:03 10.889487 T:1958237104 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
11:42:03 10.889590 T:1958237104 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
11:42:03 10.889621 T:1958237104 NOTICE: ARM Features: Neon disabled
11:42:03 10.889655 T:1958237104 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
11:42:03 10.889686 T:1958237104 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
11:42:03 10.889717 T:1958237104 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
11:42:03 10.889748 T:1958237104 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
11:42:03 10.889779 T:1958237104 NOTICE: special://envhome/ is mapped to: /home/osmc
11:42:03 10.889810 T:1958237104 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
11:42:03 10.889842 T:1958237104 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
11:42:03 10.889872 T:1958237104 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
11:42:03 10.889951 T:1958237104 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
11:42:03 10.890114 T:1958237104 NOTICE: Local hostname: AiR-Media
11:42:03 10.890198 T:1958237104 NOTICE: Log File is located: /home/osmc/.kodi/temp//kodi.log
11:42:03 10.890261 T:1958237104 NOTICE: -----------------------------------------------------------------------
11:42:03 11.116667 T:1958237104 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
11:42:03 11.135867 T:1958237104 NOTICE: load settings…
11:42:04 11.381745 T:1958237104 NOTICE: Found 2 Lists of Devices
11:42:04 11.381861 T:1958237104 NOTICE: Enumerated PI devices:
11:42:04 11.381894 T:1958237104 NOTICE: Device 1
11:42:04 11.382154 T:1958237104 NOTICE: m_deviceName : HDMI
11:42:04 11.382193 T:1958237104 NOTICE: m_displayName : HDMI
11:42:04 11.382223 T:1958237104 NOTICE: m_displayNameExtra:
11:42:04 11.382253 T:1958237104 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:42:04 11.382282 T:1958237104 NOTICE: m_channels : FL,FR
11:42:04 11.382314 T:1958237104 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
11:42:04 11.382346 T:1958237104 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
11:42:04 11.382378 T:1958237104 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
11:42:04 11.382421 T:1958237104 NOTICE: Device 2
11:42:04 11.382477 T:1958237104 NOTICE: m_deviceName : Analogue
11:42:04 11.382508 T:1958237104 NOTICE: m_displayName : Analogue
11:42:04 11.382537 T:1958237104 NOTICE: m_displayNameExtra:
11:42:04 11.382684 T:1958237104 NOTICE: m_deviceType : AE_DEVTYPE_PCM
11:42:04 11.382778 T:1958237104 NOTICE: m_channels : FL,FR
11:42:04 11.382811 T:1958237104 NOTICE: m_sampleRates : 48000
11:42:04 11.382841 T:1958237104 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
11:42:04 11.382885 T:1958237104 NOTICE: m_streamTypes : No passthrough capabilities
11:42:04 11.382954 T:1958237104 NOTICE: Device 3
11:42:04 11.383011 T:1958237104 NOTICE: m_deviceName : Both
11:42:04 11.383096 T:1958237104 NOTICE: m_displayName : HDMI and Analogue
11:42:04 11.383193 T:1958237104 NOTICE: m_displayNameExtra:
11:42:04 11.383225 T:1958237104 NOTICE: m_deviceType : AE_DEVTYPE_PCM
11:42:04 11.383256 T:1958237104 NOTICE: m_channels : FL,FR
11:42:04 11.383285 T:1958237104 NOTICE: m_sampleRates : 48000
11:42:04 11.383315 T:1958237104 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
11:42:04 11.383345 T:1958237104 NOTICE: m_streamTypes : No passthrough capabilities
11:42:04 11.383375 T:1958237104 NOTICE: Enumerated ALSA devices:
11:42:04 11.383404 T:1958237104 NOTICE: Device 1
11:42:04 11.383466 T:1958237104 NOTICE: m_deviceName : @
11:42:04 11.383497 T:1958237104 NOTICE: m_displayName : Default (bcm2835 ALSA bcm2835 ALSA)
11:42:04 11.383527 T:1958237104 NOTICE: m_displayNameExtra:
11:42:04 11.383555 T:1958237104 NOTICE: m_deviceType : AE_DEVTYPE_PCM
11:42:04 11.383585 T:1958237104 NOTICE: m_channels : FL,FR
11:42:04 11.383615 T:1958237104 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000
11:42:04 11.383644 T:1958237104 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
11:42:04 11.383673 T:1958237104 NOTICE: m_streamTypes : No passthrough capabilities
11:42:04 11.468147 T:1958237104 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
11:42:04 11.468428 T:1958237104 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are…
<?xml version="1.0" encoding="UTF-8" ?>
540
720
false
0
30
11:42:04 11.470181 T:1958237104 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:42:04 11.470265 T:1958237104 NOTICE: Default Video Player: VideoPlayer
11:42:04 11.470297 T:1958237104 NOTICE: Default Audio Player: paplayer
11:42:04 11.470338 T:1958237104 NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:42:04 11.470368 T:1958237104 NOTICE: Log level changed to “LOG_LEVEL_NORMAL”
11:42:04 11.470545 T:1958237104 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:42:04 11.533359 T:1958237104 NOTICE: Loaded playercorefactory configuration
11:42:04 11.533865 T:1958237104 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:42:04 11.534050 T:1958237104 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:42:04 11.691032 T:1958237104 NOTICE: Running database version Addons26
11:42:05 12.596047 T:1958237104 NOTICE: ADDONS: Using repository repository.xbmc.org
11:42:05 12.758363 T:1958237104 NOTICE: Raspberry PI firmware version: Oct 13 2016 17:21:14
Copyright (c) 2012 Broadcom
version b301dbab300729c7871442ca50f65c669446af20 (clean) (release)
11:42:05 12.758517 T:1958237104 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
11:42:05 12.758551 T:1958237104 NOTICE: cache.memorysize: 20MB
11:42:05 12.761044 T:1958237104 NOTICE: Config:
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=0x1e848
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
sdtv_aspect=1
temp_limit=85
11:42:05 12.761271 T:1958237104 NOTICE: Config:
device_tree=-
11:42:05 12.771235 T:1958237104 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
11:42:05 12.773263 T:1958237104 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
11:42:05 12.773355 T:1958237104 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
11:42:05 12.773400 T:1958237104 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 56.000000 Hz
11:42:05 12.773441 T:1958237104 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
11:42:05 12.773480 T:1958237104 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
11:42:05 12.773518 T:1958237104 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
11:42:05 12.773555 T:1958237104 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
11:42:05 12.773589 T:1958237104 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 60.000000 Hz
11:42:05 12.773625 T:1958237104 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 59.940063 Hz
11:42:05 12.773660 T:1958237104 NOTICE: Found resolution 1280 x 960 for display 0 with 1280 x 960 @ 60.000000 Hz
11:42:05 12.773695 T:1958237104 NOTICE: Found resolution 1280 x 960 for display 0 with 1280 x 960 @ 59.940063 Hz
11:42:05 12.773731 T:1958237104 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
11:42:05 12.773767 T:1958237104 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
11:42:05 12.773802 T:1958237104 NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 60.000000 Hz
11:42:05 12.773841 T:1958237104 NOTICE: Found resolution 1680 x 1050 for display 0 with 1680 x 1050 @ 59.940063 Hz
11:42:05 12.773878 T:1958237104 NOTICE: Found resolution 1366 x 768 for display 0 with 1366 x 768 @ 60.000000 Hz
11:42:05 12.773913 T:1958237104 NOTICE: Found resolution 1366 x 768 for display 0 with 1366 x 768 @ 59.940063 Hz
11:42:05 12.773983 T:1958237104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
11:42:05 12.774040 T:1958237104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
11:42:05 12.774075 T:1958237104 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
11:42:05 12.774114 T:1958237104 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
11:42:05 12.774151 T:1958237104 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
11:42:05 12.774192 T:1958237104 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
11:42:05 12.774227 T:1958237104 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
11:42:05 12.774266 T:1958237104 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
11:42:05 12.774301 T:1958237104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
11:42:05 12.774339 T:1958237104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
11:42:05 12.774374 T:1958237104 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
11:42:05 12.774410 T:1958237104 NOTICE: Found (1920x1080@60.000000) at 33, setting to RES_DESKTOP at 16
11:42:05 12.774474 T:1958237104 NOTICE: Checking resolution 16
11:42:05 13.089684 T:1958237104 NOTICE: GL_VENDOR = Broadcom
11:42:05 13.089789 T:1958237104 NOTICE: GL_RENDERER = VideoCore IV HW
11:42:05 13.089825 T:1958237104 NOTICE: GL_VERSION = OpenGL ES 2.0
11:42:05 13.089857 T:1958237104 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
11:42:05 13.089904 T:1958237104 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
11:42:07 14.294506 T:1832309744 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
11:42:07 14.305227 T:1937765360 NOTICE: Running database version Addons26
11:42:07 14.307848 T:1937765360 NOTICE: Running database version ViewModes6
11:42:07 14.311638 T:1937765360 NOTICE: Running database version Textures13
11:42:07 14.323824 T:1937765360 NOTICE: Running database version MyMusic60
11:42:07 14.341244 T:1937765360 NOTICE: Running database version MyVideos107
11:42:07 14.346067 T:1937765360 NOTICE: Running database version TV29
11:42:07 14.348583 T:1937765360 NOTICE: Running database version Epg11
11:42:07 14.350865 T:1958237104 NOTICE: start dvd mediatype detection
11:42:08 15.179806 T:1958237104 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
11:42:08 15.234327 T:1958237104 ERROR: JSONRPC: Unable to parse JSON Schema definition for “”
11:42:08 15.234427 T:1958237104 ERROR: JSONRPC: Invalid JSON Schema definition for method “”
11:42:08 15.796894 T:1958237104 NOTICE: initialize done
11:42:08 15.797015 T:1958237104 NOTICE: Running the application…
11:42:08 15.804019 T:1958237104 NOTICE: starting zeroconf publishing
11:42:08 15.805017 T:1958237104 NOTICE: CWebServer[8080]: Started
11:42:08 15.805164 T:1958237104 NOTICE: starting upnp client
11:42:08 15.808103 T:1645212656 NOTICE: ES: Starting UDP Event server on port 9777
11:42:08 15.808404 T:1645212656 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
11:42:09 16.636839 T:1937765360 ERROR: GetDirectory - Error getting
11:42:14 21.205364 T:1735943152 WARNING: CSkinInfo: failed to load skin settings
11:42:33 31.458490 T:1555035120 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
11:42:48 46.498169 T:1555035120 WARNING: Previous line repeats 2 times.
11:42:48 46.498348 T:1555035120 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/jUkGuSC9Kt29rW3x6UiB9zyZr1M.jpg
11:42:50 48.647556 T:1725981680 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
11:42:50 48.647717 T:1725981680 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/kqO36IYvWbRKMPiUeiVZUFH06Rc.jpg
11:43:04 62.455009 T:1735943152 WARNING: CSkinInfo: failed to load skin settings
11:43:04 62.664986 T:1735943152 ERROR: EXCEPTION: Non-Existent Control 300
11:43:38 96.770882 T:1555035120 WARNING: CSkinInfo: failed to load skin settings
11:46:55 293.313904 T:1628435440 ERROR: GetDirectory - Error getting
11:47:01 299.761169 T:1510990832 ERROR: Previous line repeats 1 times.
11:47:01 299.761292 T:1510990832 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type ‘exceptions.IndexError’>
Error Contents: list index out of range
File “/home/osmc/.kodi/addons/plugin.video.ardmediathek_de/default.py”, line 615, in
listVideosRss(url,showName,hideShowName,nextPage,einsLike)
File “/home/osmc/.kodi/addons/plugin.video.ardmediathek_de/default.py”, line 136, in listVideosRss
c = rssParser(content)
File “/home/osmc/.kodi/addons/plugin.video.ardmediathek_de/default.py”, line 190, in rssParser
runtime = runtimeToInt(part)
File “/home/osmc/.kodi/addons/plugin.video.ardmediathek_de/default.py”, line 197, in runtimeToInt
return int(HHMM[0])*60 + int(HHMM[1])
IndexError: list index out of range
–>End of Python script error report<–
11:47:01 299.844604 T:1958237104 ERROR: GetDirectory - Error getting plugin://plugin.video.ardmediathek_de/?einslike=True&mode=listVideosRss&nextpage=True&url=http%3A%2F%2Fwww.ardmediathek.de%2Ftv%2FMeistabgerufene-Videos%2Fmehr%3FdocumentId%3D21282514%26m23644322%3Dquelle.tv%26rss%3Dtrue
11:47:01 299.845642 T:1958237104 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.ardmediathek_de/?einslike=True&mode=listVideosRss&nextpage=True&url=http%3A%2F%2Fwww.ardmediathek.de%2Ftv%2FMeistabgerufene-Videos%2Fmehr%3FdocumentId%3D21282514%26m23644322%3Dquelle.tv%26rss%3Dtrue) failed
11:47:09 307.804688 T:1510990832 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
11:47:09 307.895721 T:1958237104 ERROR: GetDirectory - Error getting plugin://plugin.video.ardmediathek_de/?einslike=True&mode=listVideosRss&nextpage=True&url=http%3A%2F%2Fwww.ardmediathek.de%2Ftv%2FMeistabgerufene-Videos%2Fmehr%3FdocumentId%3D21282514%26m23644322%3Dquelle.tv%26rss%3Dtrue
11:47:09 307.896698 T:1958237104 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.ardmediathek_de/?einslike=True&mode=listVideosRss&nextpage=True&url=http%3A%2F%2Fwww.ardmediathek.de%2Ftv%2FMeistabgerufene-Videos%2Fmehr%3FdocumentId%3D21282514%26m23644322%3Dquelle.tv%26rss%3Dtrue) failed
11:47:11 309.151550 T:1716515824 ERROR: Unable to find plugin
11:47:11 309.151825 T:1958237104 ERROR: GetDirectory - Error getting plugin://
11:47:11 309.152313 T:1958237104 ERROR: CGUIMediaWindow::GetDirectory(plugin://) failed
11:47:19 317.182190 T:1735943152 WARNING: CSkinInfo: failed to load skin settings
11:47:19 317.380981 T:1735943152 ERROR: EXCEPTION: Non-Existent Control 300
11:47:20 318.469391 T:1735943152 WARNING: CSkinInfo: failed to load skin settings
11:47:20 318.631256 T:1735943152 ERROR: EXCEPTION: Non-Existent Control 300
11:47:43 341.852753 T:1725981680 WARNING: CPythonInvoker(12): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
11:51:33 571.882080 T:1555035120 WARNING: CSkinInfo: failed to load skin settings
11:51:34 572.025208 T:1555035120 ERROR: EXCEPTION: Non-Existent Control 50
11:51:40 578.318237 T:1475585008 WARNING: CSkinInfo: failed to load skin settings
11:52:22 620.337036 T:1475585008 ERROR: CCurlFile::Open failed with code 404 for http://download.osmc.tv/kodi/addons/jarvis/krypton.xml.gz.md5
11:52:22 620.337463 T:1475585008 ERROR: Open - failed to open source http://download.osmc.tv/kodi/addons/jarvis/krypton.xml.gz.md5
11:52:22 620.337585 T:1475585008 ERROR: CRepository: failed read ‘http://download.osmc.tv/kodi/addons/jarvis/krypton.xml.gz.md5’
11:52:22 620.650391 T:1475585008 ERROR: CCurlFile::Open failed with code 404 for http://download.osmc.tv/kodi/addons/jarvis/krypton.xml.gz.md5
11:52:22 620.650696 T:1475585008 ERROR: Open - failed to open source http://download.osmc.tv/kodi/addons/jarvis/krypton.xml.gz.md5
11:52:22 620.650818 T:1475585008 ERROR: CRepository: failed read ‘http://download.osmc.tv/kodi/addons/jarvis/krypton.xml.gz.md5’
11:52:22 620.710693 T:1958237104 ERROR: GetDirectory - Error getting addons://repos/
11:52:22 620.710876 T:1958237104 ERROR: CGUIMediaWindow::GetDirectory(addons://repos/) failed
11:52:27 625.164551 T:1958237104 ERROR: GetDirectory - Error getting addons://repos/
11:52:27 625.164917 T:1958237104 ERROR: CGUIMediaWindow::GetDirectory(addons://repos/) failed
11:52:50 648.820679 T:1735943152 WARNING: CSkinInfo: failed to load skin settings
11:52:50 648.997620 T:1735943152 ERROR: EXCEPTION: Non-Existent Control 300
11:52:55 654.004761 T:1628435440 WARNING: CPythonInvoker(14): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.[/details]
