What is recommended setting for ‘Adjust Display Refresh’ for 24p (1080p) content? My display can run at 24hz or 60hz. Advantages or disadvantages of either? With a quick test I couldn’t tell a big difference.
I realize 60hz will create 3:2 pulldown (I think) which may induce jitter? But is there disadvantages to runnning 24hz?
Just it to always or on start/stop and all content should play correctly.
Thanks Tom.
Thx. I have never really understood the difference between ‘Always’ and ‘On Start/Stop’. Wouldn’t it normally only adjust when you start a video?
Very rarely a movie will change frame rate during playback, this could be the way it was intended, but normally its down to issue with the encode. So setting it to always, you should always get smooth playback.
Thanks Tom.
